Resets RIPng parameters to the default value.
| vlan-name | Specifies an IPv6 configured VLAN. |
| tunnel-name | Specifies an IPv6 tunnel. |
| all | Specifies either all IPv6 configured VLANs or all IPv6 tunnels. |
N/A.
Issuing the command unconfigure ripng resets all the interfaces and the global configuration to the defaults, and disables RIPng, as that is the default.
The following command resets the RIPng configuration to the default for the VLAN finance:
unconfigure rip finance
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
